96 150 faststrike
late96
I have a fastrike that has a intermitant stall. Will be cruising and will just shut off. Has restarted so far. any ideas. One last thing, I think a friend jump started battery with the trolling motor batteries which is 24 volt but can't comfirm this. Thanks
tashasdaddy
Re: 96 150 faststrike
24 volt use 2 batteries, to make the 24 volts, doubt that is your problem. does it immediately restart? have you check the emergeny kill lanyard, sometimes they get worn, and a juggle can activate them. short in ignition wiring, especially the black/yellow wire, which is the kill wire.
late96
I know that there are two batteries to make 24 volts, I ment that I can't confirm that he did this except his wife told him there was smoke from engine cowl when jup starting it. Have since replaced regulator as it was overcharging. Thanks
tashasdaddy
that was probably the smoke. you did not answer all my questions.
