Re: '96 200 hp Johnson carbs replacement
We'll assume you're talking about the carb assembly (carbs and throttle body assembly), not just the carb body. Yes, no problem at all. Just be sure to use the air silencer base and cover from the 93. The "thumbscrew" airbox stays with the 96 carbs, the base & cover airbox stays with the 93 carbs.
Just curious, why do you want to do this?
