Rebuilding '96 200hp. #6 piston (port-bottom)is scuffed in the area of the wrist pin ends. Can see very light marking(scuff) on cyl. wall - top & bottom - can polish out.. Area on piston about<br />1 1/2" wide where scuff (pin ends). Other cyls OK Pin OK. Retainers OK. Discovered no stats in motor.Corrosion - almost none.<br />OK to reuse piston? Ideas on cause - stats gone? Heads good color. Piston tops look good.Bearings look good. Pre-mixing fuel.<br />Any suggestions/ideas greatly appreciated.
