96 200hp salt water Oil sensor issue
Tommylex
I have a 1996 200hp carb saltwater series. I just want to say this motor is great. I have not had one major problem with it since I bought the boat in 2005. (unknown hrs). Recently I got a low oil level alarm. When I took the cover off I noticed the reservoir inside the motor was low. I used the manual switch located on the CDI and was able to fill the reservoir back up to the normal level. I ran the boat again and experianced the same problem. After doing some troubleshooting this is what I found:
I know the oil pump located in the bilge attached to the main oil tank is good because I was able to manually fill the reservoir tank. I also had this issue about 2 years ago and replaced the pump.
I decided to check the sensor which is attached to the top plug of the reservoir tank in the motor. At first I had a green fill arrow on my gauge after I manually filled the reservoir tank back up. After troubleshooting I noticed that it would stay at yellow even if it was filled up. The sensor (from what I understand) will tell the tank pump to start filling, as well as give you your levels on your gauge and the low level alarm. The low level alarm will also activate when the tank in the bilge is low.
The sensor plugs into the CDI so I removed the plug and performed a continuity test using the black wire as the common. I checked the float on the sensor, which by the way does move freely on the stem, at 3 different locations. At high, fill, mid (yellow on the gauge), and low I received continuity on each wire telling me that the sensor might be good.
Now here is the deal. I was looking over the schematic for the CDI and I cannot see anything else controlling the oil fill other then the sensor in question. I spoke with a mechanic who was unsure, but agreed with me. I called my local parts dealer (who are pretty expensive but always have the parts I need) and they quoted me $160.00 for a new sensor which is non- refundable. Before I blow the money I want to see if anyone else here has experienced a similar problem or knows what the problem might be.
Thank you in advance
Tom.
rodbolt
Re: 96 200hp salt water Oil sensor issue
ya done trouble shot the system but did not care to observe.
the yellow lamp indicates not enough oil for automatic transfer so the ECU wont try.
either the remote tank switch failed or the wiring to the remote tank switch failed.
yellow on the gauge has nothing to do with the engine mounted tank.
check at the remote tank connector, black to engine ground.
check between the black and black red at the remote tank for continuity with the tank about half full.
then check between the tank connector black/red to the ECU connector black red for continuity.
Tommylex
I will check that in fact I noticed that it was only statying at yellow after I removed the sensor in the main tank to check it. Just note, before I messed with the remote tank I was sitting at green and I still had the problem.
You are saying I should have continuity between the red an black when the tank is "half full"?
rodbolt
yep, but now the story changes and the above may not be pertanint.
do some forum searches about precision blend and oiling.
any posts I have made concerning a yamaha v6 2 stroke with precision blend from 1996 to present is how your system works.
could also be the filter at the remote tank is clogged and the engine now can use oil faster than it can transfer.
a quick test for this.
make sure the remote tank is 1/2 full or more, make sure at key on you have a green lamp on the tach.
then with the key on engine off remove that vynil tube from the bottom of the engine tank. drain into a suitable container.
when the alarm goes off reinstall the tube.
from there it should refill the tank and shut off in 180 seconds or less.
post your full model number just in case you actually have a 1995 motor.
the transfer system is slightly different on motors from 1990-1995 and the 96 up V6.
Tommylex
It will be sometime before I can get the model # to you because I am working. I will also look into troubleshooting that as well.
Thanks again
