96+ 4.3 to 92 4.3
mrsmith35sg
I have done a great deal of reading but it can only do so much for my limited knowledge. I have a 92 mercruiser 4.3 that has set for a while and I havent been able to get to turn over. I had planned on upgrading this motor before any of this happened.
I have the opportunity to purchase a 96+ 4.3 auto short block in pretty good shape rotating assembly and for pretty cheap. If i plan on putting rebuilt vortec heads, a 2114 intake, and edelbrock 1409 carb on this newer block, will i be able to use anything from 92 engine (alternator, starter etc...)
I obviously know Ill need a marine head gasket set, but just wondering if this would be a good or reasonable choice to replace my 92 motor by building a 96+ to replace it. Thanks for your patience with my ignorance!
mrsmith35sg
Re: 96+ 4.3 to 92 4.3
Opporunity is fading, so any help is very helpful at this point
Gary H NC
All the externals should bolt up.
You need to put brass core plugs in the block.
Also if the newer motor has a truck cam it should be ok but if not the cam will need replaced or it will be a dog.
Ayuh,... It should be a fairly Easy swap...
mrsmith35sg
Truck cam as in just out of a normal 1/2 ton pickup?
