jcnhwildcat
- Joined
- Jun 17, 2008
- 5
Something burned out in my 1996 40HP Merc (4 cyl), I believe this is the rectifier/voltage regulator (see below)? Had trouble with the tach cutting out (more often not working), could that have been an indication of an impending problem with the rectifier? Also, I installed a Blue Sea Systems Dual Battery system before the season started and probably put 50-60 hours fishing (trolling with the outboard and bass fishing w/ electric motor) before this happened. If I did the install improperly, would it have gone this long before burning out the regulator? Though I've heard this is a common problem with Merc rectifiers.
