Just a quick question to confirm what I already think. I took it out and ran it for 5-7 mins and it ran BEAUTIFUL! Then it started to run rough and even killed. I touched the top of the heads after I had it out of the water and the one side seemed a lot hotter than the other. I pulled the T-stats out after it cooled and one was gunked up with little pebbles or shells and was still open and the other was closed. I check the closed one in a pan of water and it opened at 170?.
Question is, will it run rough and even stall if the temps are uneven? I'm going to replace BOTH T-Stats tomorrow.
THANKS!
Compression - OK
Fuel - OK
Spark - OK
THANKS!
Compression - OK
Fuel - OK
Spark - OK
