96-98 Mercury 115 hp 4 cyl. stator mounting plate help
NoFearForce
I need help finding a 96-98 Mercury 115 hp 4 cylinder stator mounting plate. I have looked everywhere and can not find a part number or even the part. Any help would be greatly appreciated. Thank you.
Serial # is ?-----Or is this the plate that all the electrical bits mount on ?----I think the stator mounts to the block.
NoFearForce
No it's the one that's under the flywheel that holds the crank seal. The stator also mounts to it.
Faztbullet
The seal mounts in the upper bearing and stator bolts to block on a 4 cylinder.....what do you really have????? What your describing is for a inIine 6 motor.They made a V6 115Hp but it don't use a stator.
NoFearForce
It's a 4 cylinder 115 but I found the part #819312A 1. I'm converting a 1987 force 125 cdi to mercury cdm thunderbolt ignition. Thanks for the help Fatzbullet!
