Should I be concerned with this? I have done the sea foam treatment and it smoothed out the idle and over all ride quite a bit. But I still do have a slight miss or hiccup in my lower rpm range cruising. Maybe the 1100-3300 range when just cruising. Every once in a while the motor will miss. It gives a slight shake that you can feel. Does not happen at wot. Could it be fuel filter or line? Someone else told me if it was a fuel filter or line it would be more noticable at higher rpm's. Would this be better off left alone. I'm a realtively inexperienced with boat motor maintenance. Thanks, Ryan
