96 Evinrude e150eled intake screens and impeller
jawjadawg
I see two options for intake screen - regular and high volume. How do I know which is needed, or will either suffice? Also, is replacement of the screens an easy task without having to pull gears or shafts? As for the impeller, am I reading the service manual correctly that I need to pull gears to replace the impeller? Thank you for your input.
Faztbullet
If it has 4 hole intake its standard.......
If standard you will need to pull water pump apart and will need replacement wear plate gasket......
Sounds like a Selco manual :( No you do not remove anygear to replace impeller or screens
