'96 Glastron GS205 40th Anniversary Edition - Interior Parts.
jwhendry
I bought this boat in 2012 and took it to the lake 3 times. The 3rd day the motor quit. I tore it down and could only salvage the heads to rebuild. It was worn smooth out and bored 60 over already. I took that motor out and built a 383 and put in it. We took it to the lake for a shake down run and wasn't in the water long and noticed a knocking sound coming from the bell housing area. So we had to have done something wrong there. I didn't use the flywheel that came with the original motor. I used the one that came with the rotating assembly I bought. Should I have taken the outdrive off and done something. Since I found this site I have done a lot of reading to figure it out. I'm sure I need to change the bellows and gimbal bearing because there was a leak in the transom area and a leak behind the rub rail it looked like. I didn't get to the lake in 14 at all. I got discouraged and fed up and quit working on the boat. I'm ready to get started again and would like a little direction from the more knowledgable guys here. What other things do I need to do to get it lake ready again. I can't find many interior parts for it or info on this boat. I wanted to find the original stickers for it but can't find those either. I'm going to restore the boat this year hopefully if I can find everything. I got a guy that's gonna do the interior. It looked good when I bought it. Then the cover ripped and it got weathered. It sure didn't take long to go downhill. My fault now I got to pay for it. Thanks for all the help in advance. This is a great site with a lot of info. I'll try to post pics.
jwhendry
Thanks for the info. Where can I find interior parts such as the stickers and radio holder. Tabs to hold the trim on. Thanks.
GA_Boater
JW - Changed the thread title so it doesn't get confused with your motor thread.
We need to know what you need. Pics would help.
Tnstratofam
To get replacement stickers you may have to get some custom made. As far as the radio holder goes you may have to try to improvise one. The nice thing about it is you can virtually remake the interior any way you want.
jwhendry
I will get some when I get home. The pics I had taken aren't close enough to tell. They look like Christmas trees is the best I can explain it lol
