tach does not work properly, shows 500 rpm all the time. engine off, volt meter on battery reads 12 volts, with engine idling, volt meter on battery reads 12.5 volts. idle it up and volt meter reads 13 volts. appears alternator is working. do I have a rectifier problem or do I buy a new tach and see if that works.
