Hey guys, this is only my 2nd posting so still pretty new to this whole thing so please bare with me. I have a 1996 mariner 15hp outboard. Started it up for the 1st time this year and it runs great. But I noticed the water stream coming from the tell-tale was very weak so I figured I need a water pump rebuild, new impeller and all that. Ordered a rebuild kit, installed it and still the same problem. Weak stream. I blew out all of the lines in case it was clogged with mud anywhere but it was fine. Put a new thermostat in. Same issue. Getting very frustrated I pulled the power head out and noticed that the gasket that connects to the bottom of it was in rough shape. So ordered that and changed it. Reinstalled everything. Fire it up and it has a great stream! Shooting out like a garden hose. So I'm thinking I have the problem solved. WRONG! I tried revving up the engine and it seems that the higher the rpms, the weaker the stream gets until it finally stops. At idle it's perfect. Higher revs it's a very weak.
Long story short: I changed the impeller, all gaskets in water pump housing, new thermostat, checked pickup tube with compressed air to see for leaks. Blew out all lines and changed gaskets on the bottom of the power head. I'm at a loss for what else it could be. HELP!!
