'96 Mercruiser 3.0 LX Compression Numbers
snowbrd84
Bought a new boat and decided to check the compression today. My compression numbers on a cold engine were 125 160 150 150.
Carb needs to be rebuilt before I can run it to bring it up to operating temp to test again, but is that 125 likely to be an issue?
Naw,...... Recheck it after ya get it runnin',......
snowbrd84
Thanks for the reply. Going to pull the carb, rebuild, and give her another go.
snowbrd84
Rebuilt the carb and the thing fired right up and ran without needing to give it any throttle.
Let it run for 20 minutes, turned it off, pulled the plugs, tested from front to back and got 150/170/160/160
So the 125 went up to 150 with the engine warmed up and all looks good.
Check your gauge, anything over 150 is suspect. If the gauge checks out, cylinder #2 has water in it
snowbrd84
I don't see any water in the oil and the spark plugs all looked good. Where could water be coming from?
