96 mercruiser power trim
jwkoehn
power trim has worked fine up until now raised unit all the way up then would not go back down I could hear the switch/relay working at the pump after 6 or 7 tries the pump started working again. has been ok since my concern is that this is the start of a real problem with the unit . any suggestions?
fendersfender
Re: 96 mercruiser power trim
bad trim solenoid.....that was my problem....somewhere here there is a link to a trim trouble-shooting guide.
Don S
Here is the troubleshooting procedures for your trim/tilt.
  • A1G2 Trim Troubleshooting.pdf
jwkoehn
How big of a job is it to replace the brushes in the pump motor?when I tap on the motor in the up or down mode the pump starts running until next time .Do I have to pull the entire power trim pump to replace the brushes?
Don S
The parts are replaceable, rather you can do it or not depends on your skills. The problem is probably more than just worn out brushes. Most likely water corrosion.
Here is the section from the manual on the trim pump motor http://www.boatfix.com/merc/Servmanl/14/14a5.pdf
If you have to ask that question, changing the brushes in the motor is probably a bit much for you to tackle.
