MichaelMullis
- Joined
- Sep 18, 2003
- 131
Help, I have a 96 ranger, 2.3L with auto trans. I noticed an oil leak when I changed the oil last week. I thought at first that my drain plug was dripping, but since then I found that the plate that is behind the drain plug is where the oil is coming from. I removed plate and had about 5-6 oz of oil drain out. I can see the flywheel with this plate removed and can see what looks like a piece of some type of gasket hanging down and oil seeping off of this material. I think this may indicate a rear seal leaking but do not know. Any suggestions would be helpfull. I have 99k on this truck and it runs great. Is a rear seal hard to replace? Should I consider rebuilding or replacing this motor.<br />thanks<br />michael
