jim j geezer
- Joined
- May 16, 2012
- 189
Model: 225.581998
Serial: OE128531
I've run it in a test barrel, but yesterday was the 1st time I've had it on a lake. Started OK but failed to plane out my 12' semi-V. The load was a full 6G tank of fuel, a fullsize (big & heavy) marine deep-cycle battery, front-mounted foot-control trolling motor, me (about 185#) and some fishing tackle & beer. I placed the fuel tank & battery just forward of the rear seat.
Fiddling with the single mixture control I was able to get it to just plane, but found it idled rough and seemed to miss on 1 cylinder. (Got it to max speed then riched it up maybe 1/8 turn)
1. Possible dirty or mis-set points on 1 cylinder.
2. I need to check & compare compressions.
3. Possible fouled plug.
Is there some voodoo Jedi mind trick to setting that single mixture adjustment?
Thanks
Jim J Geezer
Serial: OE128531
Thanks
Jim J Geezer
