Marion Moore
- Joined
- Feb 6, 2005
- 200
My engine will not pee. I have just installed a used lower unit (see post below) on my 96 Suzuki DT115S w/EFI. The used unit appears to be off of a motor either without EFI or a DT140. It has a subwater intake tube. The tube is not present and the intake is blanked off on my original lower unit. Even with the tube present shouldnt the water pump have enough suction to pick the water up? I get nothing. The pump impeller is new. I verified the upper water tube is open by blowing air through the engine block.
Last night I ordered a new blanking plate and solid rubber bushing for the sub tube and water inlet interface with the hope that this will help as well as a suspect lower unit to water tube bushing. Any other input or anyone with experience with this problem would be very helpful.
