96 suzuki dt140
offshore99
Would lower units from other suzuki engine sizes fit my motor? I have a long shaft-25 inches.
Thanks
offshore99
Re: 96 suzuki dt140
Thanks for the info. Do you know what year range i have to work with? I saw on Brownspoint that the gearcase housing for a dt140 was 1986-2001. Is the entire lower unit in that same range of years?
deejaycee_2000
Re: 96 suzuki dt140
as far as I know you can only use between 1986 to 1995 as they are identical, the lower unit might be the same from 96 - 01 but the accessories might be different (trim & tilt etc.)
