96 Yamaha 115 2 stroke intermitant no fire
dehrlich
I have an intermittent no fire on #1 cylinder. I switched coil packs and problem is still with #1 cylinder. I ohmed the signal wire from the CDI to the coil pack and seemed fine. I unpluged the signal wire and pluged it back in while runing and coil started firing. This has worked several times. Do the CDI units fail intermittently?
