sangerwaker
- Joined
- Jul 29, 2004
- 2,064
I spent most of the afternoon today tracing wiring on my motor and I'm stumped.<br /><br />I've had this issue for quite a while, but I've just charged my battery before I take the boat out. I'm tired of having to do that.<br /><br />It's definitely not the battery. It held a charge all winter sitting in my basement. Only took 5-10 minutes to charge up today. I put my voltmeter in between the positive terminal on the battery and the positive batter lead and was showing a 2.05 amp draw. I started disconnecting things to try to isolate the draw. In a nutshell, I couldn't find it.
<br /><br />I'm wondering if anyone has had a similar problem and/or where I might look further. <br /><br />I pulled the pin connector for the controls, all power trim bullet connectors, the stator wires to the voltage regulators, the outpt wires from the regulators, tach wire, temp sensor and a few more. <br /><br />I also checked both cables for shorts by a continuity test and the motor block. Nothing leaking there. <br /><br />Any ideas would be appreciated.
