cousinabe
- Joined
- Nov 13, 2001
- 765
I have twin 1997 Yamaha 225 Salt Water Series II engines. One of the engines will not idle below 1200rpms.<br /><br />After changing the plugs and commisioning the boat, one engine will not idle below 1200 rpms.<br /><br />When I first start them, they normally stay at 1200 and come down to about 800rpm once warmed up.<br /><br />I stabilize the fuel and top off the tanks prior to winter storage. In the spring I change the plugs and gap them to .35 as well.<br /><br />I did turn the idle set screw down, but that only got it to 1000rpms and does not seem the the correct fix.<br />I looked for a vacuum leak and did not find one.<br />The engines have 400 hours on them.<br /><br />Any thoughts?<br />How do the engines come down in idle once warmed?
