New to me '97 90 SPL, J90TSLEU. I have on history on this motor. Great compression, 130 - 135 on all 4 cyls. No spark on spark tester.
Went thru ignition troubleshooting per factory manual.
Stop circuit test, key switch test - OK.
Charge coil tests - OK
Sensor coil test - OK
Power Pack test - cyls 1 & 3 160 - 165 volts, cyls 2 & 4 135 volts, manual spcs 150 volts or higher. Replaced power pack with new BRP unit.
Coil tests, ohmmeter tests only - OK
Plug wire tests - 3 good, 1 bad - replaced bad one.
With new power pack I have cyls 1 & 3 147 - 148 volts, cyls 2 & 4 160 volts, still no spark or occasional spark on all cyls with spark tester.
What am I missing? I've gone end to end of factory tests except coil power tests. What are the chances of 4 coils all being bad under load? They all check OK on ohmmeter tests and look fine, no cracks, corrosion, blisters, etc.
Any suggestions gratefully accepted.
Thanks in advance.
Thanks in advance.
