J90TSLEU, it seems the VRO is mixing way too much oil into the fuel. I first had trouble after running at cruise for 20 mins. then idling in neutral, it stalled after a minute or 2. It was hard to start, but by bumping the primer quickly with the high idle lever about half way up it started and ran rough like it had a fouled plug or 2. I put it in gear and was able to get it cleared out after a little running. It seemed to run OK at cruise, but I have a 5+ min. no wake zone to get back to the launch ramp. I noticed it was putting out a lot of white exhaust smoke after a couple of minutes of running at slow speed. It stalled again and was real hard to start, again using the primer and high idle lever, I think it needed to dilute the oil rich fuel.
Back at home on the earmuffs it ran, but was putting out real thick white exhaust smoke and a lot of exhaust oil residue drained out after I turned it off.
The spark plugs were fuel and oil wet, not really fouled up, with the center insulators light tan as they should be in a good running engine.
Has anybody had a similar problem with the VRO seeming to mix too much oil? I know lots of guys have had them mix too little or none at all. Is this a simple fix to the VRO system, or is a new pump required? Of course I could go the bypass and pre-mix route as an option.
I thought maybe it was starving for gas causing the oil rich mixture, but she runs fine at all RPM otherwise until it gets oil fouled at low RPM.
Thanks in advance for your help and advice.
