I recently did a decarb of my 1997 90hp evinrude spl. I followed the procedure listed in the FAQ here http://forums.iboats.com/showthread.php?t=158076. I did this with the muffs on in my driveway. After the decarb I replaced the plugs.
I then had the boat out last weekend and it ran great for probably a total of 1 hour of run time. I then tried to start the motor and it would not run below 1500 rpms. When it was running it was spitting and shaking and there was almost a thumping noise coming from the engine. I could start the engine with it reved, but as i would lower the rev it would stall immediately. Also, while i had it reved around 1500 rpm if i quickly pushed the key in for the choke the engine would rev up to around 4000 rpm then drop quickly. Not sure what i did or even if these topics are related.
I know its next to impossible to diagnose a problem from this description but the mechanic can't look at if for 3 weeks so any suggestions would be greatly appreciated.
