97 Evinrude Gas Leak
95starcraft
When I pumped up the gas primer the pump became hard and then I noticed some gas leaking around the oil line that connects to the bottom of the VRO, and also on the starter side the carbs are leaking, I am wondering that when I put on the new rubber gasket if that didn't seat properly and gas is leaking, is this possible to leak from here.
Brent
