Re: 97 Fast Strike 115- Oil dripping from prop
I have a 98 Johnson 115 ELECM and it does the same thing as you describe when I run it on the muffs it never gets hot enough to burn off the oil like it does when you run it under power. Nothing to worry about other than the mess when it drips. Motor runs great and no problems if I don't flush it on the muffs after running it all day. Just residual unburned oil - like they say better to much than not enough.\Happy boating great motors. Starts in a flash-runs like an antelope and no smoke when under way.
