Put a new starter on my motor because the old starter's gear froze in the "up-starting" position. The new starter worked the first time, the motor ran for about 15 seconds, then the motor died (which is not unusual). Now the new starter can barely turn the flywheel. I tried rope starting the motor, with the key on and in neutral, but I can only turn the flywheel 1/2 of a rotation before it gets too hard to turn. Just for kicks, I removed the spark plugs and the starter easily turned the flywheel. From my crappy car experience, it acts like the battery is dead, but it measure 12.5V with a cheap voltmeter.
Any ideas what is wrong? Should I be able to rope start this motor? Of course I'm worried that something is seized in the motor.
