Re: 97 horizon 190/OMC Cobra I/O tranny engagement?
Have you checked the gear lube?
Pull the back cover and make sure the shift arm on the shift mechanism is going all the way into both forward and reverse.
Best way to check is pull the prop off. Run the engine on muffs. Put in forward and see if you can move (By Hand) the shift arm further into the fwd. position
