97 Merc 150 EFI water pressure
crazy4bass
Just a quickie, when I hook up my engine to a garden hose to crank it on land should I have a stream out the pee hole and/or have water pressure? Had the impeller changed last year but just now getting around to getting going again and I'm not sure if I should see some water pressure or not without a test tank or going to the lake.
p.s. - engine has a hose port not muffs.
Thanks
fishinman123
Re: 97 Merc 150 EFI water pressure
You should have water pressure with a clamp on garden hose attachment!
crazy4bass
Not sure what you mean by a clamp on the attachment. There's no attachment, host screws right into the back of the engine. Thanks
crazy4bass
Ok, just got back from the lake. Backed her in so I could submerge the foot and as expected no pee stream and no pressure. Last time it was the impeller, I've read this is easy to change.. any thoughts?
Dukedog
That port is for "back-flushing only" (motor not runnin). Its not for runnin' tha motor. Pretty sure its only on tha salt water and/or offshore type motors normally. You can possibly do some damage.................
crazy4bass
Checked the manual and it says you can run the engine at idle using the flushing port. Doesn't say if it should pee. Still, no pee and no pressure with the boat in the water so something is either blocked or the impeller stripped. Guy at the marina told me last year they tend to do that after sitting for a while. I'll pick up a pair of muffs before exploring further, maybe the dirt dobbers or a spider clogged a line...
Bill Kilgore
Code:
I use a piece of weed eater string to clean out the tell tale, works well.
crazy4bass
Code:
Actually I did that, because the weed eater line fit perfectly and was stiff enough to push anything out of the way. Didn't help though. Still nada... great idea though.
crazy4bass
After reading and watching some videos on how to replace the impeller, I pulled the lower unit this after. It was pretty simple.
Looking at the impeller it looks fine to me, the blades are curved but I know that's normal after it used. Housing looks great as well. All I know to do at this point is take the impeller to the shop and get a new one and put it all back together and see what happens.
Here's the crux. The impeller was changed this time last year, at least that's what the mechanic said they did (same issue, no water pressure). He said that sometimes when they sit over the winter when you go to crank the engine the first time in the spring/summer it strips the impeller (or something like that). Well, I brought the boat home, immediately hurt my back and it's sat under the carport until recently. Pretty sure I never tested it once we brought it home, it certainly never went into the water since it was in the shop last. So I'm thinking that possibly using the flush port doesn't get enough water to the impeller and it maybe hurt it. I noticed in one video that the mechanic talked about adding some grease to the blade ends when reinstalling to protect the impeller from the owners that go home and crank it in the driveway (he said lack of water).
Anyway, given this is a wear part, seems like might as well replace it anyway, but my understanding is this is the main part of the water pump. The rest being (according to the diagram) looks to be all forged steel or non-mechanical. Is this correct? Short of the lower water pump being cracked is there anything else to it?
Any other thoughts on what might could be wrong if this doesn't fix it?
Thanks
