Hi all,
There's a clacking noise between the back of the engine and the transom. It's been going on for about 1 year. Brought the boat to the dealer last year and they changed the gimbal bearing(it was bad). Noise is still there. I thought maybe the exhaust shutter, but seems the noise is more towards the coupler or in that area.
The noise is only in low rpm, noise stops when you turn the steering wheel and starts again when it's turned all the way to the left or right and when it's in low rpm. Noise doesn't change when you put it in gear or raise/lower drive unit.
I brought the boat today to the dealer and they pulled the drive out, and said the coupler is fine. They think it might be a valve that is stuck. How could the noise stop when you turn the steering wheel if it's a valve problem? Is this possible?
Any help is appreciated!
Thanks,
Thanks,
