97 Mercruiser 3.0 lx Alpha one Shift problem
soloblazer
Hey guys thanks for all help from my last forum, but have another issue. I just put boat in water for first time this year, and it will shift in and out of gear perfect when not running, but when running it will go into reverse pretty easy, but when triing to go from reverse to neutral or forward its really hard, and sometimes you have to push so hard its goes past neutral and into forward, and vis versa, making it really hard to pull up to docks and such. The engine is idling about 900 rpms or maybe a little less., someone has said something about a kill switch or something not sure what that is. but when the engine is off you can shift perfect and its does go into gear fine. it just seems like when its running its hard to shift in and out of gear, really hard to get to neutral again. thanks in advance for the help
