soloblazer
- Joined
- May 18, 2009
- 28
i have a mercruiser 3.0l w. alpha one. its really hare to shift in and out of gear, either forward or reverse. if i just use the throttle and not shift gears the shifter moves easy, but when trying to shift in and out gear its very very hard. somethings its goes easy, but most time its hard. reverse is a little easier. it does this whether in or out of water and whether its running or not running its about the same. once in gear its runs great and when it actually does move it shifts smooth (doesn't grind or at least very very little) its also hard to go from gear to neutral. any ideas. it makes it really hard pulling up to docks and such..
thanks in advance.
thanks in advance.
