97 Volvo Penta 5.7L GLPLKR I/O Parts help
trailshredder
With the key on, I have 2 purples with 12v, one purple with 0 and the ground.
trailshredder
Got a chance to play with this today.
I have 12 volts on 2 of the 3 purple wires, when the ignition is in the on position and 12 volts on all three when in the start position (cranking).
The MOB safety switch in normal mode has continuity across the ignition terminals and no continuity across the magneto terminals and when pulled it has continuity across the magneto terminals and no continuity across the ignition terminals.
I have tried numerous ways of hooking up the wires on the MOB switch and nothing has worked. The engine only runs while cranking, as soon as I let of the key, its wont stay running, as if I am shutting it off immediately.
This is the problem, the purple wires should have 12V on all 3 when the ignition is ON and the MOB switch is ON. You want all purple wires to be on the I terminals of the MOB switch. Can bypass by jumping all purple wires together, but make no connection to the black. The one which is turned on during cranking is being done by the start circuit back feeding the purple (electric fuel pump)
Normally this would not happen because of a blocking diode. The puzzling part is if the diode was put in backwards it could happen, but does not explain why 12V is not supplied by the other purple wire unless the MOB is not wired correctly or not making contact. If the diode was shorted, the you could not turn the motor off because the ALT would keep supplying power
trailshredder
Is there any chance it could be a faulty starter relay or breaker?
Looked in the LK manual and its showing the same as I have. Need BruceB to assit because I'm missing something I guess. Using the GL-A thru GL-E show the similar wiring, and don't see any relay and if a fuse blew I don't see if running at all.
Check the starter wiring on the small terminals. Should have purple/yellow on the left and Yellow/Red on the right
trailshredder
Got a chance to play with this last night. Still no luck! I have tied all three purple together and verified the starter wiring to the small terminals. I took a video of the boat starting and dying.
Only way I know to find the issue is with a voltmeter. Turn key ON and start tracing where until it is found
How do I know if I have the GL-A or GL-E to use your wiring diagrams?
Don't know but the Purple wires all go to the same locations on both. I have drawings for A thru E and posted the A and E because BruceB mentioned it should have a presolite distributor, he should have more input then I on the wiring
wiring colors are standard American Boat and Yacht Council Standards
COLORITEMUSE
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
BrownGenerator ArmatureGenerator Armature to Regulator
BrownPumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
GreyTachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
OrangeCommon FeedDistribution Panel to Accessory Switch
OrangeFeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
PurpleInstrument FeedDistribution Panel Electrical Instruments
RedPower FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
YellowGroundNegative / Neutral Main Return
Yellow w/RedStarting CircuitStarting Switch to Solenoid
