97 Yamaha 115
mevans27205
Ok simple queston, does the male pigtail from the Oil ijection with two wires have to be pluged in. It has two wires in it, green/red green/black.
I was wondering if this could cause any isues not being pluged in.
thanks Mike
rodbolt
Re: 97 Yamaha 115
nope, will run fine with it unplugged.
you wont have any tach visual indicates.
mevans27205
Re: 97 Yamaha 115
Hey thanks for the reply Rodbolt.
That will narrow My problem down alot, Did a motor swap which was running fine and now it only seems to want at half the speed or drops back to half after a short distance. Im thinking maybe temp related. Its a jet outboad that was on a flat bottom jon and now on a tunnel, Maybe not cooling enough. I will try and take it back out and take the temp sensor out and see if that fixes the problem. I have a new h2o impelar coming in tommarow.
thanks Mike
rodbolt
Re: 97 Yamaha 115
what?????
use the original thread.
I dont recall
last post on this one too
