alley mechanic
- Joined
- Apr 15, 2011
- 100
Hello all, well i have been having this issue with my 98 115 intruder with ois ignition for at least a year now, thought i had it solved where i had a ignition coil that when warm was acting not normal the ohm meter would jump all over when you tapped the coil so i replaced it went out to see how it ran last year in oct it was a very cool day low 40s to 50s . Now over the winter i rebuilt all 4 carbs just due to i had not even touched them since i bought the outboard and i thougt it was time to go threw them, this year i took the boat out for the first time anouther cool day all was well starts up easey smooth idle and part throttle 6000rpm wide open was happy , well my first tornament starts up easey smooth idle and part throttle 6000 rpms wide open, fished at one spot 1 hour go to next 30min goto the next 40min no problem noe the day was cool over cast windy well went to my last spot for 1 hour then decided to go to anouther spot well motor started then quit next time it backed fired than next time it started but was missing or skipp iing i proceded slow speed and heard the motor like it was spark knocking i proceded to go back to the dock than all of a sudden it started to run ok no problems its like somthing had to cool off before it will run good again o ta i also changed out the impeller the temperture went up in the 70s when this happened could it be the stater optical sensor or the rectifier regulater it has been doing this since last year cant figure it out maybe some of you techs might shed some light on this issue.
Thank you
alley mechanic
Thank you
alley mechanic
