98 115 spl cooling ?
captbjack
i have installed 98 115 spl, started it up today and is peeing good but seems like the heads are getting to warm, so i unhooked hose from thermostat to head and no water when i restarted. is this normal or do i need to do some digging.
HighTrim
Re: 98 115 spl cooling ?
If there was no discharge at operating temps, the t stats may be stuck closed. When were they last replaced?
captbjack
it has been sitting about a year. before that im not sure.
HighTrim
I would drop the lower unit then and change the water pump as well as the t stats. Cheap parts but their failure is catastrophic. When the lu is down, remove 1 tstat (thermostat) at a time and flush the water line with compressed air or the garden hose from the water line to the t stat housing, then backflush from the housing to the water line. Replace it with a new one, then repeat for the other. Clean out the water intake area. This will complete your cooling system and give you peace of mind.
http://www.meegsonline.com/tmd/waterpump.wmv
captbjack
thanks ht sounds like i have more work to do. btw great video very entertaining
