Re: 98 120hp FORCE not spiting water for a few minutes
. Mine does pee within couple of seconds. When I first bought my boat it was sitting for couple of years and it didnt pee from tell tale. it was clogged. I put a coat hanger thru, that way unclogged it.
Remove that small thermostat housing cover where the hose hooks up to. Its secured by 4 number 10 metric bolts then remove the thermostat and test it to see if it works. Boil a pot of water and drop the thermostat in it then watch it open up. If it opens up, put it in a cold cup of water and watch it close. if that checks out ok. Hook up your muffs and turn the water on and watch if water comes out of the thermostat housing. if it does turn the water off quickle before you make a mess. This way you will find out if there are clogging problems in passages. If water comes out its good, put the boat in water and run the engine and test it again. If no water comes out your water pump is out.
Im trying to help you diagnose if your thermostat is operating as it should.
