98 50hp EVINRUDE SPL RPM DROP @ WOT
sgtcuh60
I have a 98 50 Hp Evinrude SPL Idles fine.But @WOT "5800 RPM's" after about 10- 15 minutes suddenly drops to about 49000rpm's then jumps bact up to 5800 "as though the throttle was pulled backand then pushed right back to wot" also when @ 4600 rpm's it happens but it's not such a drop in rpm's and it's a shorter almost like a sputter. Is this in the carb or fuel feed system?
D
DJ
Guest
Re: 98 50hp EVINRUDE SPL RPM DROP @ WOT
Possible fuel strarvation. Does your primer bulb go flat when this happens?
