98- 50hp4strokeExcessive blowby
sonofjohn
Engine will idle all day long,throttle up @I get oil forced through breather tube and into silencer. Any suggestions before I tear it down?
sonofjohn
Re: 98- 50hp4strokeExcessive blowby
Found the problem. I pulled the powerhead @ found the mounting bolts loose! To no avail I replaced powerhead gasket. Problem not solved.Pulled powerhead,tore down motor,found camshaft retaining bolt missing. done!
