powerhouse635
- Joined
- Jun 23, 2011
- 5
I have a 1998 Johnson 60* 115, when its in gear it won't go past 2500 rpm (SLOW mode), carbs are clean and no leaks, fresh gas and oil (in reservoir) vro pump is new, diode in harness was replaced. Pulled thermostats temporarily to run it cooler...no change. Disconnected temp sensors in both heads....no change. In neutral, in the water, i can rev up to 5000+...thinking the rev limiter shouldn't have let me do that...unless????....any ideas out there??
