98-99 Johnson 90HP Check Engine Light
Lavachild
Check engine light on the dash buzzes for 15 seconds or so and then the light remains on while engine is running. The boat has been running fine until now. The intakes are not clogged, it is spitting water and is burning oil when at idle. Seems to run fine. Any suggestions? Thanks!
mike481050
Re: 98-99 Johnson 90HP Check Engine Light
leak or blockage in the fuel system. Can cause major damage if left unchecked.
Lavachild
wouldnt it stall or run rough if it was in the fuel system? are there some things I can check?
