I need to order 2 parts for a 98 alpha 1 gen 2.
I need the oil oring that seals the upper and lower case oil gally part number
Second part is the lower case rubber bushing/seal that rides on the main lower case shaft that seats on the impeller housing.
Please let me know if you guys know these part numbers.
I split my case to inspect and lost the oil ring and the shaft seal seems to have a small tear on it probably from being seated to far.
