sunbird 18
- Joined
- May 19, 2008
- 78
Just got this boat/engine. 3rd time taking it out. Ran fine 1st day, 2nd day I noticed a bit of sudden random power loss (drops 100rpm) at cruising speed(3500rpm) muffled backfiring noticed. It feels like it drops a cylinder for 5 sec or so then picks it back up. cold starts have been getting more difficult. I changed out a stuck open t-stat and changed the plugs. Took her out today and no difference. Still dropping a cylinder and getting even more hard to start/rough idle. Pulled her out of the water and flushed it out and noticed that the engine is missing! While the engine is running, I pulled the plug wire off the top left plug and it made NO DIFFERENCE!! Pulled the middle plug on the left side at the same time and STILL NO DIFFERENCE!! Its missing on 2 cylinders! Any other plug wire removed and the engine stalled. When out on the water, it seemed to be running decent at mid rpm-WOT, maybe a bit less holeshot, but still not too bad.
checked the plug spark and all spark strong....hmmmm.....
Seems to have all the upgrades, pinned heads, soft fuel rail lines, but still running air cooled EMM. Compression shows 110 on all on the right, 100 on all on the left.
ANY IDEAS???
ANY IDEAS???
