'98 Force 120 loses water pressure
RadioWaves
Help! I replaced the water pump in my Force 120 and I'm losing water pressure above 4200RPM. At 4200 its 9PSI. It falls to 2 or 3 psi above 4200!! Any ideas??
The Marine Doctor
Re: '98 Force 120 loses water pressure
Behind the water pump there is a rubber grommet that runs across the Gearcase.<br /><br />This MUST be siliconed as exhaust will enter the water pump and cause Low water pressure.<br /><br />TMD
RadioWaves
When I took it apart I didn't notice any grommet near the water pump. I changed the whole water pump assembly out. If I disassemble it again what does this thing look like??
