98 Gamefisher 9.9 Hp pull start help
travis385
I just bought my first boat which came with a 1998 Gamefisher 9.9 hp motor. From what I can tell online everyone is saying Force made these motors Mercury bought out Force and Sears just re badged them as Gamefisher. Anyway I went hunting the other day and it started up one pull and ran great. After hunting I got ready to head back but couldn't get the pull start to work. From looking at it there is a lever that keeps the pull start from turning if I reach into the motor and manually unlock it it will start . I can't seem to find any adjustments or figure out why it keeps staying locked. I can't see anything that would move it out of the way. The part is called the stop-starter pulley interlock. I also noticed shifting has gotten a little harder not sure if that has something to do with it or not.I have attached the parts diagram. The part I am talking about is part number 1. Thanks for any help.10040942-00003.jpg
fishrdan
Re: 98 Gamefisher 9.9 Hp pull start help
The shifter "has to be" in neutral to pull the start cord. If it's in neutral and the interlock is stopping the pull start cord, you'll need to check out the interlock linkage operation.
I've never messed with the interlock linkage on my Force/Gamefisher, but have pulled the start cord enough times while in D or R,,, to know it isn't turning over in D or R...:rolleyes:
brim_buster
on mine I removed that stupid lever because the cheesey F-N-R lever was picky to get just right in the neutral spot. I have a complete tore down one if you need a parts motor:joyous:
travis385
That's what I figured I'll just take it off. I will keep that motor in mind sure ill need something eventually. Thanks guys.
acdc96
yeah the shifting on these motors suck. if i want to go into reverse after shifting into neutral from forward i have to take the cowling off and move the pull start lock to get it to shift. also, put new gear lube in the lower unit helps with shifting as well. grease the linkage as well.
1991 force 9.9hp
