I have twin '98 Johnson 225s. I bought these motors used a few months ago. The port motor has always been a little cold natured, liked to stall at idle when cold. When it warmed up it was ok.
Today I could not get it to idle for any length of time at all. It starts and runs for 10 or 15 seconds and stalls. Will rev up in nuetral but stalls if I start it, put it in gear and try to throttle up. I changed the fuel water seperators, there was not visible water when I dumped them into a bucket and let it settle. I put a set of plugs in it and it seemed a little better but still will not stay running. I also took off the small fuel filter at the motor, it was clean and no restrictions.
I am going to set up a fuel line to a 5 gal can with a seperate fuel line and see what it does. Anyone have any other suggestions, things to check?
