ebear
- Joined
- Sep 10, 2007
- 57
A buddy of mine recently picked up a sea ray with a 98 mercury 115. I runs 30-40 mph so I would conclude that off idle it runs fine. But.........
Compression, spark, fuel, fuel pressure are all good. #1 and 2 mixture screws are set at 1 1/4 and timing is set to 0 (spec -2 to +4) At an idle it sounds as if it is laboring. one thing that I noticed is; at an idle I can unhook #3 and 4 plugs (one at a time) and it makes no difference in the running of the motor. The carbs are spotless and synced. plugs on 3 and 4 are wet. What in the 2 stroke world can cause a motor to have spark, fuel and good compression and still not fire correctly. also, I swapped plugs around with no change.
