Hey crom or anyone that can help, I'm a first time user ;however, I have been reading iboat questions and mostly crom's answers with great interest for some time now. I find myself needing help with a motor problem that I know I can fix once a diagnosis is made. <br />Problem: motor runs great at various throttle positions including full speed (5000)rpm for 10 - 20 minutes or so after initial startup but then suddenly cuts back to about 3400 rpm at full throttle. Once the motor starts this behavior, it will not run at full rpm (5000)without coaxing. I did discover that the engine will run at 5000 rpm if I manipulate the electronic push button choke intermittently. <br />Facts !!:<br />1. After extensive mason jar test, I can find not a trace of water in the gas tank. 2. I did replace the entire gas supply line including the pressure bulb anyway. <br />3.I have throughly cleaned all three carbs twice using OMC's top engine cleaner and that helps for a short while. <br />4. I am finding a white substance in the air box and around the carb. throats each time the engine is run at the lake.I know that two cycle oil turns white when mixed with H2O so this has to be water getting into the motor some how.<br />5. The motor is not running hot.<br />6. The power packs have tested good.<br />7. I can find no evidence of water in the oil tank that supplies the injectors.<br />8. I found that a cleaning spray of gas into the carb. throats at the dock will fix the problem temporarily.<br />9. This motor is on a 21 ft. Tracker pontoon.<br />10.Pulled the flywheel-keyway in good shape.<br />11.My summer has been ruined because I can't figure this problem out.<br />12. If I had the money, I would pay to have this problem corrected. This is really frustrating me because I feel that this has to be something simple. <br /> Please Help !!!<br /> Thanks, JP in Ky. on Caverun
