98 SportJet 175 Stalls
Bdt 1967
Like what is said above the engine is a 98 SportJet XR2 175, it starts and Idles around great, when you go full throttle it runs fine then stalls, it also has a hard time running right at mid rpms. The boat was cruising at high rpm for about 8 min, then started acting up. Idled the boat all the way back to the boat dock took about 40 min, didnt have any problems at that rpm. It should also be noted that when the boat tries to stall if you cut the throttle it will sometimes stay running and sometimes it will simply die. Any ideas?
Thanks
Andy
